Ga door naar hoofdinhoud
Xbox 360 Wireless Controller Front Case Replacement
Wat je nodig hebt
  1. Xbox 360 Wireless Controller Front Case Replacement, Battery: stap 1, afbeelding 1 van 2 Xbox 360 Wireless Controller Front Case Replacement, Battery: stap 1, afbeelding 2 van 2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
    Vraag FixBot
  2. Xbox 360 Wireless Controller Front Case Replacement, Rear Case: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
    Vraag FixBot
  3. Xbox 360 Wireless Controller Front Case Replacement: stap 3, afbeelding 1 van 1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
    Vraag FixBot
  4. Xbox 360 Wireless Controller Front Case Replacement: stap 4, afbeelding 1 van 2 Xbox 360 Wireless Controller Front Case Replacement: stap 4, afbeelding 2 van 2
    Spudger
    $2.99
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
    Vraag FixBot
  5. Xbox 360 Wireless Controller Front Case Replacement: stap 5, afbeelding 1 van 2 Xbox 360 Wireless Controller Front Case Replacement: stap 5, afbeelding 2 van 2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
    Vraag FixBot
  6. Xbox 360 Wireless Controller Front Case Replacement: stap 6, afbeelding 1 van 2 Xbox 360 Wireless Controller Front Case Replacement: stap 6, afbeelding 2 van 2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
    Vraag FixBot
  7. Xbox 360 Wireless Controller Front Case Replacement, Vibration Motors: stap 7, afbeelding 1 van 2 Xbox 360 Wireless Controller Front Case Replacement, Vibration Motors: stap 7, afbeelding 2 van 2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
    Vraag FixBot
  8. Xbox 360 Wireless Controller Front Case Replacement: stap 8, afbeelding 1 van 2 Xbox 360 Wireless Controller Front Case Replacement: stap 8, afbeelding 2 van 2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
    Vraag FixBot
  9. Xbox 360 Wireless Controller Front Case Replacement, Logic Board: stap 9, afbeelding 1 van 2 Xbox 360 Wireless Controller Front Case Replacement, Logic Board: stap 9, afbeelding 2 van 2
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
    Vraag FixBot
  10. Xbox 360 Wireless Controller Front Case Replacement, Bottom Panel: stap 10, afbeelding 1 van 2 Xbox 360 Wireless Controller Front Case Replacement, Bottom Panel: stap 10, afbeelding 2 van 2
    • Lift the bumper panel off of the front case.
    Vraag FixBot
  11. Xbox 360 Wireless Controller Front Case Replacement: stap 11, afbeelding 1 van 1
    • Remove the rubber pad from the back of the D-pad.
    Vraag FixBot
  12. Xbox 360 Wireless Controller Front Case Replacement: stap 12, afbeelding 1 van 1
    • Remove the two 7.0 mm silver Phillips screws from the back of the D-pad.
    Vraag FixBot
  13. Xbox 360 Wireless Controller Front Case Replacement: stap 13, afbeelding 1 van 2 Xbox 360 Wireless Controller Front Case Replacement: stap 13, afbeelding 2 van 2
    • The D-pad is secured to its backing by two diagonal clips, shown in red.
    • Use a pair of tweezers and squeeze the clips together to release the D-pad from its backing.
    Vraag FixBot
  14. Xbox 360 Wireless Controller Front Case Replacement: stap 14, afbeelding 1 van 2 Xbox 360 Wireless Controller Front Case Replacement: stap 14, afbeelding 2 van 2
    • Lift the D-pad backing out of its compartment on the front case.
    • The D-pad remains below the front case.
    • The D-pad will fall once its backing is removed. Be sure to support it as you remove the backing.
    • The backing is slotted to its compartment to ensure that it will always be aligned properly.
    Vraag FixBot
  15. Xbox 360 Wireless Controller Front Case Replacement: stap 15, afbeelding 1 van 1
    • Remove the rubber pad from the back of the input buttons.
    Vraag FixBot
  16. Xbox 360 Wireless Controller Front Case Replacement: stap 16, afbeelding 1 van 2 Xbox 360 Wireless Controller Front Case Replacement: stap 16, afbeelding 2 van 2
    • Using a pair or tweezers, remove the following buttons from the front panel:
    • A Button
    • B Button
    • X Button
    • Y Button
    • Start Button
    • Select Button
    • Guide Button
    Vraag FixBot
  17. Xbox 360 Wireless Controller Front Case Replacement: stap 17, afbeelding 1 van 1
    • Using a pair of tweezers, remove the LED ring from the front panel.
    Vraag FixBot
  18. Xbox 360 Wireless Controller Front Case Replacement: stap 18, afbeelding 1 van 3 Xbox 360 Wireless Controller Front Case Replacement: stap 18, afbeelding 2 van 3 Xbox 360 Wireless Controller Front Case Replacement: stap 18, afbeelding 3 van 3
    • Insert a spudger between the lower panel and front case.
    • Slide the spudger along the gap between the two case components.
    • Lift the lower panel off of the front case.
    Vraag FixBot
Conclusie
19 andere personen hebben deze handleiding voltooid.
Brett Hartt
132.073 Reputatie
144 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
25.710 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 115
Altijd: 13,991
