Inleiding
Give your games some direction. Replace the D-pad on your Xbox 360 wireless controller.
Wat je nodig hebt
Depress the battery release button on the top of the controller.
Remove the battery holder from the controller.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use a pair of tweezers to peel the barcode sticker from the battery compartment.
Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
Lift the vibration motor out of the front case.
Lifting from the headphone jack and power plug, remove the logic board from the front case.
23 andere personen hebben deze handleiding voltooid.
