Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Grasp the hard drive assembly and press the release button while lifting its front edge.
Remove the hard drive assembly from the top vent.
Gereedschap gebruikt in deze stap:Xbox 360 Opening Tool$4.99-
Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
Pry the front edge of the bottom vent away from the faceplate.
To release the clips, work from the front edge of the bottom vent.
While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
Repeat the same process to release the two center clips on the bottom vent.
Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
Insert the flat edge of a spudger between the faceplate and the outer casing near the power button.
Run your spudger along the edge of the faceplate to release the clips securing it to the front of the console.
Repeat the same motions as previously mentioned to release the left side of the faceplate.
Remove the faceplate from the front face of the console.
The top vent is secured to the console via clips. The first two clips are located underneath the top vent closest to the faceplate, as shown in the pictures.
Insert the flat end of a spudger into the small gaps previously mentioned to release the clips.
To release the clips, work from the middle of the top vent.
While slightly lifting the front edge of the top vent, use the tip of a spudger to push the clips closest to the center of the top vent towards the inside of the console.
Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox's upper case.
Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox.
Remove the top vent from the 360.
Stand the console vertically with the top edge facing down.
Carefully peel the warranty sticker off the console.
Use the flat end of a spudger to release the following latches:
Above the front-facing USB ports.
Beneath the front-facing USB ports.
Above the Memory Unit slots.
Insert the flat end of a spudger and pry upwards to release the last remaining latch located above the eject button.
Slightly lift the front portion of the lower case to ensure that the latches in the front have been completely released.
Press the Xbox 360 opening tool down into the clips securing the lower case to the upper case near the I/O ports.
While pressing down on the tool, push the lower and upper cases apart to separate the retaining clips.
While pushing the upper and lower cases apart, use the tip of a spudger or the finger of an Xbox 360 opening tool to push the long clip highlighted in red toward the center of the 360.
The clip should release, leaving the clips near the power connector as the only thing holding the upper and lower cases together.
Press the Xbox 360 opening tool down into the two remaining clips near the power connector.
Push the upper and lower cases apart to fully release the retaining clips.
Grasp the back portion of the lower case and lift it upwards to separate it from the console.
39 andere personen hebben deze handleiding voltooid.
