Ga door naar hoofdinhoud
Xbox 360 Hard Drive Replacement
Wat je nodig hebt
  1. Xbox 360 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 2 Xbox 360 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 2
    • Grasp the hard drive assembly and press the release button while lifting its front edge.
    • Remove the hard drive assembly from the top vent.
    WARNING: Just replacing the drive will not make it work correctly. Microsoft has married the drives to the motherboard. Hence, in order to get full operation out of the drive you'll have to perform more steps not listed here. Search in the FAQ on this specific topic for more details. Otherwise, before buying a new drive, try cleaning the inside of the old one and/or replace the belt involved in opening and closing the drive door.
    - Good Luck
    Eric - Antwoord
    Thanks..helped!
    joseph zulu - Antwoord
    bress the button and lift with the same hand! i thought mine was stuck because of this pic!!!
    Maths with Luigi - Antwoord
Conclusie
66 andere personen hebben deze handleiding voltooid.
2 opmerkingen
that was very difficult
Michael Drawdy - Antwoord
that was so hard i dropped my xbox and not it has the red ring of death
Nednal404 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 125
Altijd: 25,448
