Ga door naar hoofdinhoud
Xbox 360 Faceplate Replacement
Wat je nodig hebt
  1. Xbox 360 Faceplate Replacement, Faceplate: stap 1, afbeelding 1 van 3 Xbox 360 Faceplate Replacement, Faceplate: stap 1, afbeelding 2 van 3 Xbox 360 Faceplate Replacement, Faceplate: stap 1, afbeelding 3 van 3
    • Orient the console horizontally with the I/O ports side down.
    • Insert the edge of a spudger between the faceplate and the outer casing near the power button.
    • Run your spudger along the edge of the faceplate to release the clips securing it to the front of the Xbox.
    • Remove the faceplate from the front face of the console.
    and what do I do after I remove the faceplate???? just curious
    Herbert Rowe - Antwoord
    The main purpose of this guide is serving as prerequisite for other guides.
    VauWeh - Antwoord
Conclusie
84 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Ok so my drive wasn't opening and i eventually came to the conclusion the drive was bad but i was wrong while replacing the drive the original one was plugged into the computer to obtain the drive key and it opened and closed fine, the problem is the case ...when i have the drive plugged into the xbox and tge actual xbox case is off it works once i put the case on it squishes the drive and it won't open, nothing appears wrong with any component. Help from anyone is appreciated
Societyburning - Antwoord
You don’t have to have tools for this.
brockchristian93 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 45
Afgelopen 30 dagen: 147
Altijd: 28,788
