Inleiding
When you can't download the game you just have to have follow this guide to replace your Wi-Fi card.
Wat je nodig hebt
Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
7 andere personen hebben deze handleiding voltooid.
