Ga door naar hoofdinhoud
Xbox 360 Controller USB Cord Replacement
Wat je nodig hebt
  1. Xbox 360 Controller USB Cord Replacement, USB Cord: stap 1, afbeelding 1 van 1
    • Remove the tamper seal sticker from the back of the controller.
  2. Xbox 360 Controller USB Cord Replacement: stap 2, afbeelding 1 van 1
    • Remove the seven screws from the back of the controller.
  3. Xbox 360 Controller USB Cord Replacement: stap 3, afbeelding 1 van 1
    • Separate the front and back face-plates of the controller.
    • Use spudger or plastic opening tools if necessary.
  4. Xbox 360 Controller USB Cord Replacement: stap 4, afbeelding 1 van 1
    • Remove the Tumblers from the front face-plate.
    • Do not disconnect the tumblers from the circuit board.
  5. Xbox 360 Controller USB Cord Replacement: stap 5, afbeelding 1 van 1
    • Remove the circuit board from the front face-plate with the tumblers still attached.
    • Be careful not to remove the buttons from the front face-plate to avoid further complications.
  6. Xbox 360 Controller USB Cord Replacement: stap 6, afbeelding 1 van 1
    • Place the circuit board on a non-conductive surface with the thumb sticks facing up, and the USB cord facing you.
    • Static surfaces may damage the circuit board.
  7. Xbox 360 Controller USB Cord Replacement: stap 7, afbeelding 1 van 1
    • Turn on the soldering iron,
    • Remove the solder, which is directly to the right of the left thumb stick, from the four linear nodes by using the desoldering wick and the soldering iron.
    • Circuit board should remain in the same position as is shown in step 6.
    • Improper use of the soldering iron will result in injury.
    • Direct contact between the circuit board and soldering iron may damage the board.
  8. Xbox 360 Controller USB Cord Replacement: stap 8, afbeelding 1 van 2 Xbox 360 Controller USB Cord Replacement: stap 8, afbeelding 2 van 2
    • Remove the wire housing from the opposite side of the circuit board.
    • Do not apply excessive force on the circuit board. This will cause it to break.
  9. Xbox 360 Controller USB Cord Replacement: stap 9, afbeelding 1 van 2 Xbox 360 Controller USB Cord Replacement: stap 9, afbeelding 2 van 2
    • Connect the new housing and new wire to the back side of the circuit board. The wire should come out from the top of the controller.
    • The order of the wires (from left to right) is: black, green, white, red.
  10. Xbox 360 Controller USB Cord Replacement: stap 10, afbeelding 1 van 1
    • Repeat step 6.
  11. Xbox 360 Controller USB Cord Replacement: stap 11, afbeelding 1 van 1
    • Re-solder the four nodes (left to right) with the soldering iron and soldering wire.
  12. Xbox 360 Controller USB Cord Replacement: stap 12, afbeelding 1 van 1
    • Reassemble, and get back to gaming!
Conclusie
By following these steps, you will be able to replace your Xbox 360 controller's USB cord. Hopefully this guide is useful to you and will elongate the life capacity of your Xbox 360 controller.
35 andere personen hebben deze handleiding voltooid.
Sam Bahl
930 Reputatie
1 Handleiding geschreven
Colorado Springs, Team 7-1, Mcmichael Fall 2015 Lid van Colorado Springs, Team 7-1, Mcmichael Fall 2015
UCCS-MCMICHAEL-F15S7G1
3 Leden
2 handleidingen geschreven
16 opmerkingen
Where did you bought the replacement wire/cord?
gatchie24 - Antwoord
The first one took me 1 hour and half, the second one 20 minutes. Here are some comments.
- It was very hard to unsolder the defective USB plug. I had to use a high temperature on the solder iron, and pull the plug from the other side as I was alternating between the 4 pins.
- There are 4 pins but 5 holes on the board. Make sure to check what one is useless before unsoldering.
- It is best to dismount the controller face down and to keep it that way. The face plate has all the buttons and they will fall if you turn it upside up.
Jean-Yves Tinevez - Antwoord
What happen if I disconnect the tumblers
Xander Redstorm - Antwoord
Thank you for this explicitly post.
Albert Einstein - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 122
Afgelopen 30 dagen: 570
Altijd: 75,212
