Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Onderdelen
Geen onderdelen opgegeven.
  1. Insert the tip of a small flathead screwdriver between the X clamp and its retaining post on the heat sink. Pry the X clamp away from its retaining post until it is lifted above the small groove cut into the retaining post.
    • Insert the tip of a small flathead screwdriver between the X clamp and its retaining post on the heat sink.
    • Pry the X clamp away from its retaining post until it is lifted above the small groove cut into the retaining post.
    • If necessary, insert your screwdriver parallel to the motherboard between the X clamp and its retaining post. Twist the screwdriver to fully release the X clamp from its retaining post.
    • Repeat this process for all four corners of the X clamp.
    • When removing the last corner of the X clamp and holding the motherboard upside down, be sure to catch the CPU heat sink to avoid damage from it falling.
    • Remove the CPU heat sink from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,168
