Ga door naar hoofdinhoud
Xbox 360 Bottom Vent Replacement
Wat je nodig hebt
  1. Xbox 360 Bottom Vent Replacement, Bottom Vent: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Xbox 360 Opening Tool
    • Stand the console vertically with the bottom edge facing up.
    • Throughout the following opening procedure, the finger of an Xbox 360 opening tool can be used in place of a spudger.
    • Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
    • Pry the front edge of the bottom vent away from the faceplate.
  2. Xbox 360 Bottom Vent Replacement: stap 2, afbeelding 1 van 3 Xbox 360 Bottom Vent Replacement: stap 2, afbeelding 2 van 3 Xbox 360 Bottom Vent Replacement: stap 2, afbeelding 3 van 3
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
    • You will insert the tool into the holes molded into the white plastic side case pieces.
  3. Xbox 360 Bottom Vent Replacement: stap 3, afbeelding 1 van 2 Xbox 360 Bottom Vent Replacement: stap 3, afbeelding 2 van 2
    • To release the clips, work from the front edge of the bottom vent.
    • While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
  4. Xbox 360 Bottom Vent Replacement: stap 4, afbeelding 1 van 2 Xbox 360 Bottom Vent Replacement: stap 4, afbeelding 2 van 2
    • Repeat the same process to release the two center clips on the bottom vent.
  5. Xbox 360 Bottom Vent Replacement: stap 5, afbeelding 1 van 2 Xbox 360 Bottom Vent Replacement: stap 5, afbeelding 2 van 2
    • Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
  6. Xbox 360 Bottom Vent Replacement: stap 6, afbeelding 1 van 1
    • Remove the bottom vent from the 360.
Conclusie
69 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
cool thanks for the tip
exavier smith - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 156
Altijd: 30,597
