Ga door naar hoofdinhoud
X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement
Wat je nodig hebt
  1. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement, Battery: stap 1, afbeelding 1 van 1
    • Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
    • Unclip the two clips to remove the battery cover.
  2. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: stap 2, afbeelding 1 van 1
    • Unplug the battery by pushing on the clip.
  3. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement, Underbody: stap 3, afbeelding 1 van 1
    • Unscrew the two 2.5mm Phillips #00 screws from each side
  4. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: stap 4, afbeelding 1 van 1
    • Remove the side skirt covers on each side of the car.
  5. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: stap 5, afbeelding 1 van 2 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: stap 5, afbeelding 2 van 2
    • Lift up and remove the two side skirts.
  6. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the two 2.5mm Phillips #00 screws from the front skirt of the car.
  7. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: stap 7, afbeelding 1 van 1
    • Lift the front part of the underbody and pull it out from the main underbody.
  8. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: stap 8, afbeelding 1 van 2 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: stap 8, afbeelding 2 van 2
    • Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
    • The second image shows a closer view of the rear three screws
  9. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: stap 9, afbeelding 1 van 2 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: stap 9, afbeelding 2 van 2
    • Lift the main underbody from the shell of the car.
    • Lift up the body to expose the wiring and hardware underneath.
  10. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: stap 10, afbeelding 1 van 1
    • Remove the reflective sticker from the top of the body.
  11. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: stap 11, afbeelding 1 van 1
    • Unplug the wire connector.
  12. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement, Rear Motor: stap 12, afbeelding 1 van 1
    • Unscrew the two 2.5mm Phillips #00 screws on the white covering of the rear motor casing.
    • There is a plastic casing over the rear motor. Simply remove this plastic covering and proceed.
  13. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: stap 13, afbeelding 1 van 2 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: stap 13, afbeelding 2 van 2
    • Remove all ten 1.6mm Phillips #000 screws from the rear motor casing
    • The first image shows five screws on the side with the circuitry
    • The second image shows five screws on the opposite side of the casing.
  14. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: stap 14, afbeelding 1 van 1
    • Use a soldering gun to remove the attached wires
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Trent Peterson
454 Reputatie
3 handleidingen geschreven
Cal Poly, Team 24-3, Lancaster Spring 2015 Lid van Cal Poly, Team 24-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G3
3 Leden
9 handleidingen geschreven
Één opmerking
what size is the motor
mattsson97 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 17
Altijd: 527
