Ga door naar hoofdinhoud
X-Treme Tablet Generation 2 Speaker Replacement
Wat je nodig hebt
  1. X-Treme Tablet Generation 2 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Using a spudger and pry tool, remove the back cover. Start at the top corner, and carefully pry the back cover off of the main body.
    • Continue around the device, being careful to not dislodge the power button.
  2. X-Treme Tablet Generation 2 Speaker Replacement: stap 2, afbeelding 1 van 2 X-Treme Tablet Generation 2 Speaker Replacement: stap 2, afbeelding 2 van 2
    • Using a solder vacuum and soldering iron, release the red wire from the motherboard first, then release the black wire.
    • The speaker is held on the back cover with adhesive tape. Using a pry tool, carefully pry the speaker from the back cover.
Conclusie
Kristen John
125 Reputatie
1 Handleiding geschreven
Pasco Hernando, Team 5-4, Prince Winter 2015 Lid van Pasco Hernando, Team 5-4, Prince Winter 2015
PHSC-PRINCE-W15S5G4
6 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 317
