Inleiding
Before proceeding, make sure you have all the necessary parts and tools for this replacement guide. This is over the replacement of the motherboard for XTreme Tablet Generation 2. If you feel the need, use safety glasses and gloves when applicable.
  1. Remove cover from back of tablet. Use pick tool to pry cover from upper corner around edges until cover un-clips from case.
    • Remove cover from back of tablet. Use pick tool to pry cover from upper corner around edges until cover un-clips from case.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  3. Find and detach all connections to  motherboard.   There are connections at the battery, at the camera, ground wire, plastic connections are charging port, and SDRAM DDR3 512MB. Remove these connections from the motherboard, but leave the components in place.
    • Find and detach all connections to motherboard. There are connections at the battery, at the camera, ground wire, plastic connections are charging port, and SDRAM DDR3 512MB. Remove these connections from the motherboard, but leave the components in place.
    • Remove using soldering iron and solder vacuum to break current welds.
  4. Replacing malfunctioning motherboard with new.  Obtain new motherboard, reattach connections at  battery, at the camera, ground wire, plastic connections are charging port, and SDRAM DDR3 512MB. Reattach using before mentioned solder station.
    • Replacing malfunctioning motherboard with new. Obtain new motherboard, reattach connections at battery, at the camera, ground wire, plastic connections are charging port, and SDRAM DDR3 512MB.
    • Reattach using before mentioned solder station.
Conclusie
Dalton Croslow
97 Reputatie
1 Handleiding geschreven
IUPUI, Team S3-G3, Wilson Fall 2018 Lid van IUPUI, Team S3-G3, Wilson Fall 2018
IUPUI-WILSON-F18S3G3
3 Leden
1 handleiding geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 42
