Ga door naar hoofdinhoud
Wyze WVCR200s Side Brush Replacement
  1. Wyze WVCR200s Side Brush Replacement, Side Brush: stap 1, afbeelding 1 van 1
    • Flip the vacuum upside down so the underside of the device is facing up.
    • On the upper left of the device, you should see a spinning brush with three arms protruding out. This is the side brush.
  2. Wyze WVCR200s Side Brush Replacement: stap 2, afbeelding 1 van 1
    • To remove, grab the three arms of the brush and pull upwards. The arms should be tight, but should not require too much force to lift off.
    • Once the brush is off, a square peg that holds the brush should be visible.
    • Place the replacement brush on the square peg, and press down with moderate pressure.
Conclusie
Brendan
181 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 5-5, Ramos Spring 2023 Lid van UMass Dartmouth, Team 5-5, Ramos Spring 2023
UMASSD-RAMOS-S23S5G5
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 249
