Ga door naar hoofdinhoud
Wyze WVCR200s Bumper Replacement
Wat je nodig hebt
  1. Wyze WVCR200s Bumper Replacement, Side Brush: stap 1, afbeelding 1 van 1
    • Flip the vacuum upside down so the underside of the device is facing up.
    • On the upper left of the device, you should see a spinning brush with three arms protruding out. This is the side brush.
  2. Wyze WVCR200s Bumper Replacement: stap 2, afbeelding 1 van 1
    • To remove, grab the three arms of the brush and pull upwards. The arms should be tight, but should not require too much force to lift off.
    • Once the brush is off, a square peg that holds the brush should be visible.
    • Place the replacement brush on the square peg, and press down with moderate pressure.
  3. Wyze WVCR200s Bumper Replacement, Bumper: stap 3, afbeelding 1 van 1
    • Flip the vacuum over.
  4. Wyze WVCR200s Bumper Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the six screws along the bottom edge of the bumper.
  5. Wyze WVCR200s Bumper Replacement: stap 5, afbeelding 1 van 3 Wyze WVCR200s Bumper Replacement: stap 5, afbeelding 2 van 3 Wyze WVCR200s Bumper Replacement: stap 5, afbeelding 3 van 3
    • The small plastic connector holding the bumper in place should now be loose. Make sure it's disconnected.
    • Pull the bumper straight off of the vacuum.
Conclusie
Brandon Amado
411 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 5-5, Ramos Spring 2023 Lid van UMass Dartmouth, Team 5-5, Ramos Spring 2023
UMASSD-RAMOS-S23S5G5
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 112
