Inleiding
The Wyze Cam V2 comes with a charging port that allows you to power your device. If your charging port starts having charging problems you might need to replace it. This guide will help you through the steps of replacing it.
Wat je nodig hebt
Open up the camera stand to expose the bottom plate of the camera.
Remove two 4 mm silver screws using the Phillips #0 screwdriver.
Gereedschap gebruikt in deze stap:Tweezers$3.99
Using the angled slim tweezers, disconnect the cord and pull it gently off of the motherboard.
Remove the single 6 mm screw located deep inside the device using a Phillips #000 screwdriver.
Carefully remove the motherboard from the device.
