Inleiding
This guide shows you which screws and which pieces to remove in order to access the wheel housing.
Wat je nodig hebt
Remove the 1.2 mm Phillips screws surrounding the wheel and take off the wheel cover.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
This will require a TON of pressure on the screw. I tried it. The wheel is removable even without taking out the screw, since it does not require much force this way, either.
