Inleiding
The MiP communicates with playful sounds. A malfunctioning speaker will greatly diminish the user experience. Use this guide to replace the speaker in your WowWee MiP robot.
Wat je nodig hebt
Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
Remove the two 7.5 mm Phillips #1 screws holding the speaker bracket in place.
