Ga door naar hoofdinhoud
WowWee CHiP Robot Dog Ear Replacement
Wat je nodig hebt
  1. WowWee CHiP Robot Dog Ear Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place CHiP on its back so that its stomach is facing you.
  2. WowWee CHiP Robot Dog Ear Replacement: stap 2, afbeelding 1 van 2 WowWee CHiP Robot Dog Ear Replacement: stap 2, afbeelding 2 van 2
    • There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
  3. WowWee CHiP Robot Dog Ear Replacement: stap 3, afbeelding 1 van 2 WowWee CHiP Robot Dog Ear Replacement: stap 3, afbeelding 2 van 2
    • Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
  4. WowWee CHiP Robot Dog Ear Replacement: stap 4, afbeelding 1 van 3 WowWee CHiP Robot Dog Ear Replacement: stap 4, afbeelding 2 van 3 WowWee CHiP Robot Dog Ear Replacement: stap 4, afbeelding 3 van 3
    • Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
  5. WowWee CHiP Robot Dog Ear Replacement, Ear: stap 5, afbeelding 1 van 2 WowWee CHiP Robot Dog Ear Replacement, Ear: stap 5, afbeelding 2 van 2
    • Remove the 4 Phillips screws shown.
  6. WowWee CHiP Robot Dog Ear Replacement: stap 6, afbeelding 1 van 3 WowWee CHiP Robot Dog Ear Replacement: stap 6, afbeelding 2 van 3 WowWee CHiP Robot Dog Ear Replacement: stap 6, afbeelding 3 van 3
    • Pull up top part of toy and remove the connecting wires.
    • Unscrew the 2 Phillips head screws. CHiP should be viewed as seen in the third picture.
  7. WowWee CHiP Robot Dog Ear Replacement: stap 7, afbeelding 1 van 3 WowWee CHiP Robot Dog Ear Replacement: stap 7, afbeelding 2 van 3 WowWee CHiP Robot Dog Ear Replacement: stap 7, afbeelding 3 van 3
    • Remove the 4 Phillips screws to separate the head from the body.
  8. WowWee CHiP Robot Dog Ear Replacement: stap 8, afbeelding 1 van 2 WowWee CHiP Robot Dog Ear Replacement: stap 8, afbeelding 2 van 2
    • Remove the 4 Phillips screws on back of the head, and pull off the casing for the back of the head.
  9. WowWee CHiP Robot Dog Ear Replacement: stap 9, afbeelding 1 van 3 WowWee CHiP Robot Dog Ear Replacement: stap 9, afbeelding 2 van 3 WowWee CHiP Robot Dog Ear Replacement: stap 9, afbeelding 3 van 3
    • Unscrew the screw on the ear with a Phillips screwdriver, and pull off the plastic connector. Remove the ear from head.
Conclusie
Één opmerking
It’s almost a disassembly, probably quite hard to do. I did disassemble a MiPosaur, but some parts broke off. (!!!)
Michael Deitz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 1,517
