Ga door naar hoofdinhoud
WowWee CHiP Robot Dog Battery Replacement
Wat je nodig hebt
  1. WowWee CHiP Robot Dog Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place CHiP on its back so that its stomach is facing you.
  2. WowWee CHiP Robot Dog Battery Replacement: stap 2, afbeelding 1 van 2 WowWee CHiP Robot Dog Battery Replacement: stap 2, afbeelding 2 van 2
    • There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
  3. WowWee CHiP Robot Dog Battery Replacement: stap 3, afbeelding 1 van 2 WowWee CHiP Robot Dog Battery Replacement: stap 3, afbeelding 2 van 2
    • Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
  4. WowWee CHiP Robot Dog Battery Replacement: stap 4, afbeelding 1 van 3 WowWee CHiP Robot Dog Battery Replacement: stap 4, afbeelding 2 van 3 WowWee CHiP Robot Dog Battery Replacement: stap 4, afbeelding 3 van 3
    • Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
Conclusie
4 andere personen hebben deze handleiding voltooid.
8 opmerkingen
Where do I get a battery
cajuin6736 - Antwoord
If you find a source please let me know. Thanks
Need Help -
Heres a replacement. Be sure to order the correct plug at the auction (C plug) https://rover.ebay.com/rover/0/0/0?mpre=...
Need Help -
Did you find the battery?
aura -
those batteries
are for the copter not the dog. I need the dog battery the Chip dog needs two 18650 lithium ion batteries my battery shop could get the individual batteries but could not work on the lithium as to volatile.
v scigliano - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 33
Altijd: 5,596
