Ga door naar hoofdinhoud
Wooting 60HE Keycap Replacement
Wat je nodig hebt
  1. Wooting 60HE Keycap Replacement, Keycap: stap 1, afbeelding 1 van 1
    • Use a small, soft bristle brush to remove small hairs or dust from the keyboard.
    • For this replacement, we will be replacing the "A" keycap.
  2. Wooting 60HE Keycap Replacement: stap 2, afbeelding 1 van 2 Wooting 60HE Keycap Replacement: stap 2, afbeelding 2 van 2
    • Hook the two metal brackets of the keycap puller at a slight angle on the corners of the key.
    • Slightly tug upwards, and the key should come out smoothly. Place the key to the side.
    • It is essential to be gentle; excessive force can cause cracks or scratches on the key.
  3. Wooting 60HE Keycap Replacement: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Using tweezers, carefully extract debris from the exposed backboard of the keyboard.
    • Try to avoid the key nub, as it is lubricated, and outside contact can ruin it.
  4. Wooting 60HE Keycap Replacement: stap 4, afbeelding 1 van 1
    • Hold a multi-purpose electronics duster three inches away and at an angle from the exposed key.
    • Press the trigger in short bursts.
    • This will help get rid of any debris that you could not get from using your tweezers.
  5. Wooting 60HE Keycap Replacement: stap 5, afbeelding 1 van 2 Wooting 60HE Keycap Replacement: stap 5, afbeelding 2 van 2
    • Place a cotton swab on a napkin and lightly coat the head of the swab with 70% isopropyl alcohol.
  6. Wooting 60HE Keycap Replacement: stap 6, afbeelding 1 van 1
    • Gently pat around the white backboard of the keyboard with the cotton swab.
    • This will help get rid of any built up residue, oils, or any possible spills that could have occurred in the past.
    • Isopropyl alcohol can strip the lubricant on the key, so put emphasis on dabbing the white backboard and not the key itself.
  7. Wooting 60HE Keycap Replacement: stap 7, afbeelding 1 van 3 Wooting 60HE Keycap Replacement: stap 7, afbeelding 2 van 3 Wooting 60HE Keycap Replacement: stap 7, afbeelding 3 van 3
    • Line the keycap in the upright position above the nub and press down lightly.
    • The key should slide back in place.
Eindstreep
Aryav Balia
157 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Lid van CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
6 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 60
Altijd: 1,301
