Ga door naar hoofdinhoud
Wood Stool Leg Glide Replacement
Wat je nodig hebt
  1. Wood Stool Leg Glide Replacement, Wood Stool Leg Glides: stap 1, afbeelding 1 van 1
    • Turn the stool upside down so it is stable on the ground and the legs are faced up in the air.
  2. Wood Stool Leg Glide Replacement: stap 2, afbeelding 1 van 1
    • Clean the end of the sled gliders and the legs to remove dust and debris.
  3. Wood Stool Leg Glide Replacement: stap 3, afbeelding 1 van 1
    • Peel the sled glides off of the top of the screw on glides on all four of the legs.
  4. Wood Stool Leg Glide Replacement: stap 4, afbeelding 1 van 1
    • Use a 1.59mm drill bit and unscrew the screw from all four legs. Then remove the screw on glides.
    • Make sure the drill is faced straight up and down or the screw will become stripped.
  5. Wood Stool Leg Glide Replacement: stap 5, afbeelding 1 van 1
    • Pry the remaining part of the screw with a hammer if the screw is not drilled out all of the way.
  6. Wood Stool Leg Glide Replacement: stap 6, afbeelding 1 van 1
    • Use a 1.59mm drill bit to drill on the new screw on glides in the center of all four stool legs.
  7. Wood Stool Leg Glide Replacement: stap 7, afbeelding 1 van 2 Wood Stool Leg Glide Replacement: stap 7, afbeelding 2 van 2
    • Stick the new sled glider at the center of the screw on glides for all four legs.
Conclusie
Molly Ristig
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 388
