Ga door naar hoofdinhoud
Wolf Gourmet WGTR102S Outer Shell Replacement
Wat je nodig hebt
  1. Wolf Gourmet WGTR102S Outer Shell Replacement, Outer Shell: stap 1, afbeelding 1 van 1
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Wolf Gourmet WGTR102S Outer Shell Replacement: stap 2, afbeelding 1 van 1
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Wolf Gourmet WGTR102S Outer Shell Replacement: stap 3, afbeelding 1 van 1
    • Remove the crumb collector located on the bottom of the toaster.
  4. Wolf Gourmet WGTR102S Outer Shell Replacement: stap 4, afbeelding 1 van 1
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  5. Wolf Gourmet WGTR102S Outer Shell Replacement: stap 5, afbeelding 1 van 1
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  6. Wolf Gourmet WGTR102S Outer Shell Replacement: stap 6, afbeelding 1 van 1
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  7. Wolf Gourmet WGTR102S Outer Shell Replacement: stap 7, afbeelding 1 van 1
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  8. Wolf Gourmet WGTR102S Outer Shell Replacement: stap 8, afbeelding 1 van 2 Wolf Gourmet WGTR102S Outer Shell Replacement: stap 8, afbeelding 2 van 2
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
Conclusie
Ryan Funchess
697 Reputatie
5 handleidingen geschreven
Cal Poly, Team S22-G5, Maness Spring 2018 Lid van Cal Poly, Team S22-G5, Maness Spring 2018
CPSU-MANESS-S18S22G5
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 523
