Inleiding
If the toaster is not responding to the heat dial, try replacing the circuit board with this guide.
Wat je nodig hebt
Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
Remove the two 4mm screws found on each side of the circuit board using a Tri-point Y1 screwdriver.
Bijna klaar!
Conclusie
