Inleiding
If no electricity flows through the toaster when plugged in, try replacing the electrical connection with this guide.
Wat je nodig hebt
Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
Unscrew the ground wire using a Tri-point Y1 screwdriver. It is secured with an 8mm screw.
Bijna klaar!
Conclusie
