Ga door naar hoofdinhoud
Wobbly Wheel Replacement & Frame Tightening
Wat je nodig hebt
  1. Wobbly Wheel Replacement & Frame Tightening, Wheel & Frame Repair: stap 1, afbeelding 1 van 2 Wobbly Wheel Replacement & Frame Tightening, Wheel & Frame Repair: stap 1, afbeelding 2 van 2
    • Stick the 13mm wrench fitting over the nut of the wheel.
    • Turn the wrench right to left to loosen the nut until it comes off.
    • Completely unscrew the nut from the axel.
  2. Wobbly Wheel Replacement & Frame Tightening: stap 2, afbeelding 1 van 2 Wobbly Wheel Replacement & Frame Tightening: stap 2, afbeelding 2 van 2
    • Hold the wheel and pull it off the axle.
    • Utilize a bearing puller or a plier to loosen up the bearings.
    • Take out the bearings from the wheel.
    • Use a clean cloth to wipe down the axle to remove any dirt, debris, or old grease.
  3. Wobbly Wheel Replacement & Frame Tightening: stap 3, afbeelding 1 van 2 Wobbly Wheel Replacement & Frame Tightening: stap 3, afbeelding 2 van 2
    • Oil the bearings with WD-40 to remove any rust or dirt.
    • Make sure to oil them front and back to get rid off any unwanted sludge or corrode.
  4. Wobbly Wheel Replacement & Frame Tightening: stap 4, afbeelding 1 van 2 Wobbly Wheel Replacement & Frame Tightening: stap 4, afbeelding 2 van 2
    • Make the bearings spin with your finger.
    • Clean any extra oil/debris off the bearings.
    • Ensure the bearings move/rotate freely.
  5. Wobbly Wheel Replacement & Frame Tightening: stap 5, afbeelding 1 van 2 Wobbly Wheel Replacement & Frame Tightening: stap 5, afbeelding 2 van 2
    • Put the bearings back in the new wheel.
    • Push them into the wheel firmly to ensure their proper placement.
    • Rotate the wheel to verify.
  6. Wobbly Wheel Replacement & Frame Tightening: stap 6, afbeelding 1 van 3 Wobbly Wheel Replacement & Frame Tightening: stap 6, afbeelding 2 van 3 Wobbly Wheel Replacement & Frame Tightening: stap 6, afbeelding 3 van 3
    • Inspect the frame and look for any loose bolts.
    • Use the wrench/pliers to tighten any loose bolts until they are snug.
    • Do not overtighten, as this can damage the frame or the boot.
  7. Wobbly Wheel Replacement & Frame Tightening: stap 7, afbeelding 1 van 2 Wobbly Wheel Replacement & Frame Tightening: stap 7, afbeelding 2 van 2
    • Place the new wheel onto the axle.
    • Add any washers, if applicable.
    • Screw the nut back onto the axle using the wrench, tightening it until the wheel feels secure.
    • Make sure wheel spins smoothly and doesn't wobble or rub against the frame or boot.
    • Repeat for all other wheels.
Conclusie
Sports equipment can be expensive to buy, and instead of buying a new pair of skates, users can easily just repair the old ones. Learning this basic skill can be beneficial as it saves money and time, while ensuring less waste on our planet.
Één andere persoon heeft deze handleiding voltooid.
Muskanmeet Kaur
175 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 28
Altijd: 324
