Ga door naar hoofdinhoud
Withings Smart Body Analyzer Pressure Sensor Replacement
Wat je nodig hebt
  1. Withings Smart Body Analyzer Pressure Sensor Replacement, Withings Smart Body Analyzer Disassembly: stap 1, afbeelding 1 van 1
    • Push the battery door
    • Open the compartment
    • Gently remove the batteries from their designated positions
    • Place them aside, away from the reach of children
  2. Withings Smart Body Analyzer Pressure Sensor Replacement: stap 2, afbeelding 1 van 3 Withings Smart Body Analyzer Pressure Sensor Replacement: stap 2, afbeelding 2 van 3 Withings Smart Body Analyzer Pressure Sensor Replacement: stap 2, afbeelding 3 van 3
    • With caution, insert the plastic opening tools in between the disk and the glass face
    • It's a tight fit, so don't be afraid to apply a little bit of force
    • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
    • Gently rotate the plastic spudger around the disk to get around the adhesive
    • Gently lift the metal disk
    • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
    • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
  3. Withings Smart Body Analyzer Pressure Sensor Replacement: stap 3, afbeelding 1 van 2 Withings Smart Body Analyzer Pressure Sensor Replacement: stap 3, afbeelding 2 van 2
    • After all the above steps have been completed, proceed by removing the glass face
    • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
    • Run the plastic spudger all around the scale to increase the gap size
    • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
    • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
    • Repeat the above steps four times
    • After all the adhesives has been removed, gently lift the glass face off
  4. Withings Smart Body Analyzer Pressure Sensor Replacement, Pressure Sensor: stap 4, afbeelding 1 van 1
    • Notice the red and black wires connecting the circuit board to each of the pressure sensors.
    • Using a soldering iron and de-soldering braid, remove the soldered red and black wires from the circuit board
  5. Withings Smart Body Analyzer Pressure Sensor Replacement: stap 5, afbeelding 1 van 2 Withings Smart Body Analyzer Pressure Sensor Replacement: stap 5, afbeelding 2 van 2
    • Use a Phillips-head screwdriver to remove the screw from the sensor. There will be two screws per sensor.
  6. Withings Smart Body Analyzer Pressure Sensor Replacement: stap 6, afbeelding 1 van 2 Withings Smart Body Analyzer Pressure Sensor Replacement: stap 6, afbeelding 2 van 2
    • Remove any sensors you need and you are now ready to replace or repair depending on your needs.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ashley Dauphinee
317 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S4-G1, Julie Spring 2017 Lid van UMass Dartmouth, Team S4-G1, Julie Spring 2017
UMASSD-JULIE-S17S4G1
4 Leden
4 handleidingen geschreven
2 opmerkingen
Where do I get those replacements?
karina - Antwoord
where can I buy pressure sensors?
Andrey Kolesov - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 3,920
