Ga door naar hoofdinhoud
Wireless Xbox One Controller Bumper Assembly Replacement
Wat je nodig hebt
  1. Wireless Xbox One Controller Bumper Assembly Replacement, Bumper Assembly: stap 1, afbeelding 1 van 1
    • Remove the battery cover from the back of the controller by sliding it upwards.
  2. Wireless Xbox One Controller Bumper Assembly Replacement: stap 2, afbeelding 1 van 3 Wireless Xbox One Controller Bumper Assembly Replacement: stap 2, afbeelding 2 van 3 Wireless Xbox One Controller Bumper Assembly Replacement: stap 2, afbeelding 3 van 3
    • Using the halberd spudger, pry the grip casing upwards from the handle.
    • Remove the grip casing from both the left and right handles of the controller.
    • It helps to begin near the top of the grip casing near the trigger.
  3. Wireless Xbox One Controller Bumper Assembly Replacement: stap 3, afbeelding 1 van 2 Wireless Xbox One Controller Bumper Assembly Replacement: stap 3, afbeelding 2 van 2
    • Remove the five 9 mm Torx TR9 security screws from the top and bottom of the controller grip regions as well as from the center of the battery region.
    • The pins on the security screws can be broken off easily with a small flathead screwdriver for use of an ordinary Torx screwdriver if the security version is unavailable.
  4. Wireless Xbox One Controller Bumper Assembly Replacement: stap 4, afbeelding 1 van 1
    • Remove the back of the controller casing by lifting it up and off.
  5. Wireless Xbox One Controller Bumper Assembly Replacement: stap 5, afbeelding 1 van 1
    • Lift the internal assembly from the plastic controller case.
    • Handle gently; the motors on the bottom left and right are not firmly attached.
  6. Wireless Xbox One Controller Bumper Assembly Replacement: stap 6, afbeelding 1 van 2 Wireless Xbox One Controller Bumper Assembly Replacement: stap 6, afbeelding 2 van 2
    • Remove the top button panel from the controller by gently lifting up the hooks attached to the internals.
  7. Wireless Xbox One Controller Bumper Assembly Replacement: stap 7, afbeelding 1 van 1
    • Detach the bumper assembly by sliding one bumper to the side away from the controller and then lifting upwards.
    • Gently follow the motion indicated by the arrows.
  8. Wireless Xbox One Controller Bumper Assembly Replacement: stap 8, afbeelding 1 van 1
    • Remove bumpers and replace by inserting a new bumper assembly.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Patrick Ashman
229 Reputatie
1 Handleiding geschreven
Cal Poly, Team 2-2, Johann Winter 2023 Lid van Cal Poly, Team 2-2, Johann Winter 2023
CPSU-JOHANN-W23S2G2
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 69
Afgelopen 30 dagen: 331
Altijd: 4,631
