Ga door naar hoofdinhoud
Wintec Filemate Clear 7" Motherboard Replacement
Wat je nodig hebt
  1. Wintec Filemate Clear 7" Motherboard Replacement, Remove the Backplate: stap 1, afbeelding 1 van 1
    • Locate the four corners of the backplate.
  2. Wintec Filemate Clear 7" Motherboard Replacement: stap 2, afbeelding 1 van 2 Wintec Filemate Clear 7" Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
  3. Wintec Filemate Clear 7" Motherboard Replacement, Remove the Battery: stap 3, afbeelding 1 van 1
    • Un-stick the battery from the motherboard assembly with the plastic opening tool.
  4. Wintec Filemate Clear 7" Motherboard Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Desolder the battery wires from the motherboard.
    • The tweezers pictured point to the two solder joints.
  5. Wintec Filemate Clear 7" Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Fully remove the battery from the device.
  6. Wintec Filemate Clear 7" Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Locate each of the motherboard's 4 mm screws.
  7. Wintec Filemate Clear 7" Motherboard Replacement, Unscrewing Everything: stap 7, afbeelding 1 van 3 Wintec Filemate Clear 7" Motherboard Replacement, Unscrewing Everything: stap 7, afbeelding 2 van 3 Wintec Filemate Clear 7" Motherboard Replacement, Unscrewing Everything: stap 7, afbeelding 3 van 3
    • Remove each of the four 4 mm screws from the motherboard pictured to the left.
    • Use a Phillips #00 precision screwdriver.
  8. Wintec Filemate Clear 7" Motherboard Replacement, Detach the Motherboard: stap 8, afbeelding 1 van 2 Wintec Filemate Clear 7" Motherboard Replacement, Detach the Motherboard: stap 8, afbeelding 2 van 2
    • Use the spudger to pry the instrument array from its plastic housing.
  9. Wintec Filemate Clear 7" Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Slowly slide the spudger underneath the adhesive tape to un-sitck it.
    • Be careful not to harm the array of wires leading to this tape.
  10. Wintec Filemate Clear 7" Motherboard Replacement: stap 10, afbeelding 1 van 1
    • De-tatch the motherboard output wires from the screen using the tweezers.
Conclusie
Nicholas Ferraro
431 Reputatie
6 handleidingen geschreven
USF Tampa, Team 19-6, Blackwell Spring 2014 Lid van USF Tampa, Team 19-6, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G6
3 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 173
