Ga door naar hoofdinhoud
Windsor Willow Bottom Bracket Replacement
Wat je nodig hebt
  1. Windsor Willow Bottom Bracket Replacement, Chain: stap 1, afbeelding 1 van 1
    • The chain connects the crank arm to the gear cluster on the back wheel.
  2. Windsor Willow Bottom Bracket Replacement: stap 2, afbeelding 1 van 1
    • On the chain, locate the master link. It is a lighter gray than the other links of the chain. This is how you can break the chain for easier removal.
  3. Windsor Willow Bottom Bracket Replacement: stap 3, afbeelding 1 van 2 Windsor Willow Bottom Bracket Replacement: stap 3, afbeelding 2 van 2
    • To separate the Master Link, hold the left side of the link in your left hand and the link to the right in your right hand. Push the two links together to enable the release. Pull the links apart, one hand moving towards yourself and the other away from you. This will separate the links of the chain.
  4. Windsor Willow Bottom Bracket Replacement: stap 4, afbeelding 1 van 1
    • Once you have separated the links of the chain, pull down on the right side of the chain as shown. Pull until the chain has been fully removed from the gears. Place the chain on a paper towel or cloth to prevent getting grease anywhere.
  5. Windsor Willow Bottom Bracket Replacement, Crankshaft: stap 5, afbeelding 1 van 1
    • The crank arms can be located between the front and rear tire, directly below the seat.
  6. Windsor Willow Bottom Bracket Replacement: stap 6, afbeelding 1 van 1
    • To remove the crank arm, place a proper fitting Allen wrench into the slot at the center of the crank arm as shown. Turn the wrench counterclockwise to loosen the bolt that keeps the crank arm on the bike until it spins easily. Hold the other crank arm in place to ensure that the bolt loosens instead of spinning the crank arm.
  7. Windsor Willow Bottom Bracket Replacement: stap 7, afbeelding 1 van 1
    • Once the bolt spins easily, keep the Allen wrench in the bolt slot and turn the crank arms to speed up the removal process.
  8. Windsor Willow Bottom Bracket Replacement: stap 8, afbeelding 1 van 1
    • Remove the bolt from the crank arm. The crank arm will remain in place. Do not try to pull off the crank arm, as a special tool is required for this task.
  9. Windsor Willow Bottom Bracket Replacement: stap 9, afbeelding 1 van 3 Windsor Willow Bottom Bracket Replacement: stap 9, afbeelding 2 van 3 Windsor Willow Bottom Bracket Replacement: stap 9, afbeelding 3 van 3
    • Repeat steps 2-4 on the other crank arm. Remember, do not try to pull off the crank arms.
  10. Windsor Willow Bottom Bracket Replacement: stap 10, afbeelding 1 van 1
    • Obtain a crank puller tool. This tool has two parts, a movable threaded insert and the push bolt. Screw the crank puller into the hole left by the bolt.
    • Be sure to be gentle and thread the first few turns by hand as to not accidentally cross thread your crankarms.
  11. Windsor Willow Bottom Bracket Replacement: stap 11, afbeelding 1 van 3 Windsor Willow Bottom Bracket Replacement: stap 11, afbeelding 2 van 3 Windsor Willow Bottom Bracket Replacement: stap 11, afbeelding 3 van 3
    • Once the movable piece is tightened firmly inside the hole, turn the tool clockwise. This will pull the crank arm away from the bike and remove it completely.
  12. Windsor Willow Bottom Bracket Replacement: stap 12, afbeelding 1 van 3 Windsor Willow Bottom Bracket Replacement: stap 12, afbeelding 2 van 3 Windsor Willow Bottom Bracket Replacement: stap 12, afbeelding 3 van 3
    • Repeat steps 6-7 with the remaining crank arm. Both arms have been successfully removed.
  13. Windsor Willow Bottom Bracket Replacement, Bottom Bracket: stap 13, afbeelding 1 van 1
    • The Bottom Bracket is located at the bottom of the frame, directly underneath the saddle.
  14. Windsor Willow Bottom Bracket Replacement: stap 14, afbeelding 1 van 2 Windsor Willow Bottom Bracket Replacement: stap 14, afbeelding 2 van 2
    • On the non-drive side, insert the bottom bracket removal tool into the splines on the inside of the bottom bracket mounting ring.
    • Fit the crescent wrench onto the bottom bracket removal tool.
    • Use the crescent wrench to turn the mounting ring counterclockwise until it is loose enough to turn by hand.
  15. Windsor Willow Bottom Bracket Replacement: stap 15, afbeelding 1 van 2 Windsor Willow Bottom Bracket Replacement: stap 15, afbeelding 2 van 2
    • Turn the bottom bracket removal tool counterclockwise by hand until the mounting ring is free of the bicycle frame
  16. Windsor Willow Bottom Bracket Replacement: stap 16, afbeelding 1 van 3 Windsor Willow Bottom Bracket Replacement: stap 16, afbeelding 2 van 3 Windsor Willow Bottom Bracket Replacement: stap 16, afbeelding 3 van 3
    • Fit the bottom bracket removal tool into the splines on the drive-side of the bottom bracket.
    • Use the crescent wrench to turn the bottom bracket removal tool clockwise until the bottom bracket is loose enough to turn by hand.
  17. Windsor Willow Bottom Bracket Replacement: stap 17, afbeelding 1 van 2 Windsor Willow Bottom Bracket Replacement: stap 17, afbeelding 2 van 2
    • Turn the bottom bracket removal tool clockwise by hand until its threads are no longer in contact with those of the frame.
    • Pull the bottom bracket out of the bike frame.
Conclusie
To reassemble your device, follow these instructions in reverse order, keeping in mind that the drive-side threads are reverse threads, meaning counterclockwise turning tightens the piece and clockwise turning loosens the piece.
Walker Cobb
101 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-6, Banghart Winter 2017 Lid van Cal Poly, Team 10-6, Banghart Winter 2017
CPSU-BANGHART-W17S10G6
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 432
