Ga door naar hoofdinhoud
Window Operator Link Replacement
Wat je nodig hebt
  1. Window Operator Link Replacement, Link: stap 1, afbeelding 1 van 2 Window Operator Link Replacement, Link: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Flathead 4 mm Screwdriver
    $5.49
    Koop
    • Remove the four (4) window clips that holds the screen.
    • Your amount of window clips may vary depending on the size of your window.
    • Use the Flathead 4 mm Screwdriver to loosen the clip. The clip doesn't need to be removed.
    • Remove the screen and put it aside.
  2. Window Operator Link Replacement: stap 2, afbeelding 1 van 3 Window Operator Link Replacement: stap 2, afbeelding 2 van 3 Window Operator Link Replacement: stap 2, afbeelding 3 van 3
    Large Needle Nose Pliers
    Koop
  3. Window Operator Link Replacement: stap 3, afbeelding 1 van 3 Window Operator Link Replacement: stap 3, afbeelding 2 van 3 Window Operator Link Replacement: stap 3, afbeelding 3 van 3
    • Using the Phillips #2 Screwdriver , remove the two bolts that are holding the operator into the window frame.
    • Behind the window, you will have one self retaining nut per bolt.
    • In some cases, you will need to play with the operator in order to take it out due to the small tolerances in the window.
  4. Window Operator Link Replacement: stap 4, afbeelding 1 van 3 Window Operator Link Replacement: stap 4, afbeelding 2 van 3 Window Operator Link Replacement: stap 4, afbeelding 3 van 3
    Metal Spudger
    $2.99
    Koop
  5. Window Operator Link Replacement: stap 5, afbeelding 1 van 3 Window Operator Link Replacement: stap 5, afbeelding 2 van 3 Window Operator Link Replacement: stap 5, afbeelding 3 van 3
    Koop
    • Once the warped or broken link is removed, follow the Step 4 in reverse order.
    • You may use the Large Needle Nose Pliers to force the e-clip into place.
Conclusie
To reassemble your device, follow from step three (3) to one (1) in reverse order.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 46
Altijd: 952
