Ga door naar hoofdinhoud
Wii U GamePad Outer Case Replacement
Wat je nodig hebt
  1. Wii U GamePad Outer Case Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
    tried to unscrew the 10 Tri-Wing size Y1 screw with my iFixIt toolkit
    unfortunately the tool is too “fat” and short, it cannot reach 4 screws on the corners of the gamepad.
    having the iFixIt toolkit and needing to purchase an additional slim screwdriver it’s a shame…
    Antonello Iannone - Antwoord
  2. Wii U GamePad Outer Case Replacement: stap 2, afbeelding 1 van 1
    • Lift and remove the battery plate.
  3. Wii U GamePad Outer Case Replacement: stap 3, afbeelding 1 van 3 Wii U GamePad Outer Case Replacement: stap 3, afbeelding 2 van 3 Wii U GamePad Outer Case Replacement: stap 3, afbeelding 3 van 3
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
    Battery lifts up from the bottom not the top like the photo shows.
    Tyler Schommer - Antwoord
  4. Wii U GamePad Outer Case Replacement, Outer Case: stap 4, afbeelding 1 van 3 Wii U GamePad Outer Case Replacement, Outer Case: stap 4, afbeelding 2 van 3 Wii U GamePad Outer Case Replacement, Outer Case: stap 4, afbeelding 3 van 3
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
    I used a small blade tip to life up on the black squares that covered the screw holes. Replacing them after.. I skipped that as it seemed impossible they would even stick back down.
    Chris - Antwoord
    I am having trouble getting the two screws on the hand grips as the screws are too deep. What should I use to get them?
    [deleted] - Antwoord
    I ended up having to buy some cheap amazon screwdrivers and are very disappointed
    [deleted] -
  5. Wii U GamePad Outer Case Replacement: stap 5, afbeelding 1 van 1
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
    Do not pull by the wires! If you do, you better be pretty good at soldering.
    Brandon - Antwoord
    I agree. A circle over the plug would have been better as the picture looks like you just pull on the wires lol.
    Chris -
    Thanks for the comment. I did get a set of tweezers and the negative cable broke anyway. They really could have done a better job at using a different connector for that.
    Kristen Bartholomew -
    Great. Didn't pull on cord. Whole thing ripped off.
    August - Antwoord
    Why in the world is this thing so tightly connected?
    Andrew Moore - Antwoord
    Thanks for the comment. I did get a set of tweezers to try to pull it out but still ended up breaking the negative cable. They really could have used a better set of cables and connectors for this.
    Kristen Bartholomew - Antwoord
Conclusie
4 andere personen hebben deze handleiding voltooid.
Valentina Cerruty
3.345 Reputatie
7 handleidingen geschreven
USF Tampa, Team 1-6, Sullivan Spring 2016 Lid van USF Tampa, Team 1-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G6
4 Leden
40 handleidingen geschreven
2 opmerkingen
This doesn't show anything about taking the front of the housing off, is that relatively straightforward?
Will Prosser - Antwoord
This doesn't show anything about the L and R sticks like moving on its own when i play, do you how to fix that?
Victoria Gonzalez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 178
Altijd: 6,463
