Ga door naar hoofdinhoud
Wii U GamePad Outer Case Replacement
Wat je nodig hebt
  1. Wii U GamePad Outer Case Replacement, Battery: stap 1, afbeelding 1 van 2 Wii U GamePad Outer Case Replacement, Battery: stap 1, afbeelding 2 van 2
    • Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Wii U GamePad Outer Case Replacement: stap 2, afbeelding 1 van 3 Wii U GamePad Outer Case Replacement: stap 2, afbeelding 2 van 3 Wii U GamePad Outer Case Replacement: stap 2, afbeelding 3 van 3
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
  3. Wii U GamePad Outer Case Replacement, Outer Case: stap 3, afbeelding 1 van 3 Wii U GamePad Outer Case Replacement, Outer Case: stap 3, afbeelding 2 van 3 Wii U GamePad Outer Case Replacement, Outer Case: stap 3, afbeelding 3 van 3
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  4. Wii U GamePad Outer Case Replacement: stap 4, afbeelding 1 van 2 Wii U GamePad Outer Case Replacement: stap 4, afbeelding 2 van 2
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back plate.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Kim Arre
4.918 Reputatie
8 handleidingen geschreven
Cal Poly, Team 17-20, Forte Winter 2013 Lid van Cal Poly, Team 17-20, Forte Winter 2013
CPSU-FORTE-W13S17G20
5 Leden
38 handleidingen geschreven
2 opmerkingen
This is either incomplete or mistitled - it is a currently a back plate replacement guide.
At the conclusion of this how-to/walkthrough, most of the GamePad's hardware is still attached to the front plate, one half of the outer case.
Elijah - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 114
Altijd: 14,620
