Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
With your finger, press down and pull back on the battery connector plug.
Remove the battery from the battery case.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
Unplug outer case rumble motor connector from the motherboard with your fingers.
Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer.
Remove the white flex cable with the tweezers.
Disconnect the black and white wires off of the back of the WiFi module.
With your fingers, unplug the left speaker cable from the motherboard.
Remove the right speaker cable that's connected to the motherboard with the tweezers.
Carefully lift the black clasp. It is prone to breaking if only lifted from one point. Remove the brown ribbon by using the tweezers.
Remove these two connectors to the motherboard with your fingers.
Remove the NFC communicator.
Remove the small connector plug-in on the back.
Remove the remaining three 5.1 mm screws using the Phillips size #0 screwdriver.
Lift and remove the mother board.
13 andere personen hebben deze handleiding voltooid.
2 opmerkingen
How can i see what version off motherboard i need to buy to replace it
I got 30X52504 as number on the board
