Ga door naar hoofdinhoud
Inleiding
This guide will help you to replace the LCD display . For this replacement, you will need to use a #00 Phillips screwdriver and a small Triwing (Y) screwdriver.
  1. Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Lift and remove the battery plate.
    • Lift and remove the battery plate.
  3. With your finger, press down and pull back on the battery connector plug. Remove the battery from the battery case. Remove the battery from the battery case.
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
  4. Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case. Lift up on the back of case. Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
  5. Unplug outer case rumble motor connector from the motherboard with your fingers.
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
  6. With your fingers, unplug the left speaker cable from the motherboard. With your fingers, unplug the left speaker cable from the motherboard.
    • With your fingers, unplug the left speaker cable from the motherboard.
  7. Remove the right speaker cable that's connected to the motherboard with the tweezers. Remove the right speaker cable that's connected to the motherboard with the tweezers.
    • Remove the right speaker cable that's connected to the motherboard with the tweezers.
  8. Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer. Remove the white flex cable with the tweezers. Remove the white flex cable with the tweezers.
    • Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer.
    • Remove the white flex cable with the tweezers.
  9. With your fingers,  lift and remove bluetooth board. Remove the board carefully as there are still two wires attached.
    • With your fingers, lift and remove bluetooth board.
    • Remove the board carefully as there are still two wires attached.
  10. Disconnect the black and white wires off of the back of the bluetooth module. Disconnect the black and white wires off of the back of the bluetooth module.
    • Disconnect the black and white wires off of the back of the bluetooth module.
  11. Lift and remove the bluetooth module.
    • Lift and remove the bluetooth module.
  12. Disconnect the analog connector with tweezers.
    • Disconnect the analog connector with tweezers.
  13. Remove the blue connector using tweezers. Remove the blue connector using tweezers.
    • Remove the blue connector using tweezers.
  14. Carefully lift the black clasp.  It is prone to breaking if only lifted from one point.  Remove the brown ribbon by using the tweezers. Unclasp and release the small digitizer ribbon cable to the left of the brown ribbon. Be careful, the clasp breaks easily.
    • Carefully lift the black clasp. It is prone to breaking if only lifted from one point. Remove the brown ribbon by using the tweezers.
    • Unclasp and release the small digitizer ribbon cable to the left of the brown ribbon. Be careful, the clasp breaks easily.
  15. Remove the small orange ribbon with the tweezers.
    • Remove the small orange ribbon with the tweezers.
  16. Remove these two connectors to the motherboard with your fingers. Remove these two connectors to the motherboard with your fingers. Remove these two connectors to the motherboard with your fingers.
    • Remove these two connectors to the motherboard with your fingers.
  17. Remove the NFC communicator. When removing the NFC communicator, be careful  with the small connector on the back side.
    • Remove the NFC communicator.
    • When removing the NFC communicator, be careful with the small connector on the back side.
    • Remove the small connector plug-in on the back.
  18. Remove the remaining three 5.1 mm screws using the Phillips size #0 screwdriver. Lift and remove the mother board. Lift and remove the mother board.
    • Remove the remaining three 5.1 mm screws using the Phillips size #0 screwdriver.
    • Lift and remove the mother board.
  19. Remove the four 5.1mm screws using Phillips size #0 screwdriver. Pull the white and black cables away from the display case.
    • Remove the four 5.1mm screws using Phillips size #0 screwdriver.
    • Pull the white and black cables away from the display case.
  20. Lift and remove the grey display case with your fingers. Lift and remove the grey display case with your fingers.
    • Lift and remove the grey display case with your fingers.
  21. Gently with your fingers, press on the front of the display and it will lift up. Remove the display with your fingers.
    • Gently with your fingers, press on the front of the display and it will lift up.
    • Remove the display with your fingers.
Conclusie
65 andere personen hebben deze handleiding voltooid.
Valentina Cerruty
2.815 Reputatie
7 handleidingen geschreven
USF Tampa, Team 1-6, Sullivan Spring 2016 Lid van USF Tampa, Team 1-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G6
4 Leden
34 handleidingen geschreven
17 Opmerkingen
was really perfect to repair my device. Thank you very much for this help
Bernd Dietrich - Antwoord
In step 14 - what does the small gray ribbon do? The replacement LCD display that I got in the mail did not have it.
Stacey Hoggard - Antwoord
Its the touch screen cable. The screen I ordered did not come with one. I had to carefully remove it from my broken display and put it on the new one. Thankfully the touchscreen still works for me.
Terry Moenkhaus -
Very happy with your manual! I've fixed it.
Paulus 68 - Antwoord
Mine did not come with the touch screen either.
Edwin Kahn - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 20
Afgelopen 7 dagen: 111
Afgelopen 30 dagen: 519
Altijd: 56,668
