Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide will demonstrate how to replace the Front Cover of the Wii Balance Board.
  1. Flip device upside-down so the plastic white board is facing the ground.
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Remove the gray plastic ring from the actual foot by lifting it up.
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Separate the loose foot from the device by lifting it up.
    • Separate the loose foot from the device by lifting it up.
  4. Repeat steps two and three on the remaining four feet.
    • Repeat steps two and three on the remaining four feet.
  5. Unscrew the ten 12.7 mm Phillips #1 screws.
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Lift off the gray back cover.
    • Lift off the gray back cover.
  7. Locate the gray battery compartment. Push the tab on the bottom and lift up completely to remove the cover to the batteries.
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Unscrew the two 6.35 mm Phillips #1 screws.
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
  9. Unscrew the four 12.7 mm #1 screws.
    • Unscrew the four 12.7 mm #1 screws.
  10. Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
    • Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cory Olson
777 Reputatie
4 handleidingen geschreven
Cal Poly, Team 13-8, Forte Fall 2014 Lid van Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Leden
10 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 633
