Ga door naar hoofdinhoud
Wii Balance Board Frame Replacement
Wat je nodig hebt
  1. Wii Balance Board Frame Replacement, Unscrewing the Foot Cover: stap 1, afbeelding 1 van 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Frame Replacement, Removing the Foot Cover: stap 2, afbeelding 1 van 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Frame Replacement, Removing the Foot: stap 3, afbeelding 1 van 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Frame Replacement, Removing the Additional Feet: stap 4, afbeelding 1 van 1
    • Repeat steps two and three on the remaining four feet.
  5. Wii Balance Board Frame Replacement, Unscrewing the Back Cover: stap 5, afbeelding 1 van 1
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Frame Replacement, Removing the Back Cover: stap 6, afbeelding 1 van 1
    • Lift off the gray back cover.
  7. Wii Balance Board Frame Replacement, Battery Compartment: stap 7, afbeelding 1 van 2 Wii Balance Board Frame Replacement, Battery Compartment: stap 7, afbeelding 2 van 2
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Frame Replacement, Removing the Battery Case: stap 8, afbeelding 1 van 1
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
  9. Wii Balance Board Frame Replacement, Unscrewing the Frame: stap 9, afbeelding 1 van 1
    • Unscrew the four 12.7 mm #1 screws.
  10. Wii Balance Board Frame Replacement, Removing the Frame: stap 10, afbeelding 1 van 1
    • Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
  11. Wii Balance Board Frame Replacement, Removing the Power Supply: stap 11, afbeelding 1 van 1
    • Lift out the power supply. It is not screwed in.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cory Olson
891 Reputatie
4 handleidingen geschreven
Cal Poly, Team 13-8, Forte Fall 2014 Lid van Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Leden
15 handleidingen geschreven
Één opmerking
Top Anleitung, aber wo kann ich die Platine herbekommen? Danke!!!
Dominik - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 32
Altijd: 2,918
