Ga door naar hoofdinhoud
Wii Balance Board Foot Replacement
Wat je nodig hebt
  1. Wii Balance Board Foot Replacement, Unscrewing the Foot Cover: stap 1, afbeelding 1 van 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Foot Replacement, Removing the Foot Cover: stap 2, afbeelding 1 van 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Foot Replacement, Removing the Foot: stap 3, afbeelding 1 van 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Foot Replacement, Removing the Additional Feet: stap 4, afbeelding 1 van 1
    • Repeat steps two and three on the remaining four feet.
    how to completely remove and then put back in would be helpful as that's what the title of this post is…. right?
    Nelda Murray - Antwoord
Conclusie
Cory Olson
891 Reputatie
4 handleidingen geschreven
Cal Poly, Team 13-8, Forte Fall 2014 Lid van Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Leden
15 handleidingen geschreven
2 opmerkingen
I am in need of a foot cover. Where can I find one??
Marvin Hopper - Antwoord
This manual did not help
nbrown1959.nb - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 47
Altijd: 2,946
