Ga door naar hoofdinhoud
Wii Balance Board Foot Replacement
Wat je nodig hebt
  1. Wii Balance Board Foot Replacement, Unscrewing the Foot Cover: stap 1, afbeelding 1 van 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Foot Replacement, Removing the Foot Cover: stap 2, afbeelding 1 van 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Foot Replacement, Removing the Foot: stap 3, afbeelding 1 van 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Foot Replacement, Removing the Additional Feet: stap 4, afbeelding 1 van 1
    • Repeat steps two and three on the remaining four feet.
Conclusie
Cory Olson
891 Reputatie
4 handleidingen geschreven
Cal Poly, Team 13-8, Forte Fall 2014 Lid van Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Leden
15 handleidingen geschreven
2 opmerkingen
I am in need of a foot cover. Where can I find one??
Marvin Hopper - Antwoord
This manual did not help
nbrown1959.nb - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 38
Altijd: 2,922
