Inleiding
Replace the 120GB SSD hard drive with an equal or larger hard drive.
Wat je nodig hebt
Flip the computer over.
Remove the six screws with a 2 mm Allen key.
Carefully remove the back panel, as well the left and right panel.
Using a Phillips #2 screwdriver, remove the four screws on the heatsink that cools the processor unit.
Remove the heatsink.
Conclusie
To reassemble the device, follow the instructions in reverse order.
Met dank aan deze vertalers:
de en
100%
Deze vertalers helpen ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
