Deze vertaling geeft mogelijk niet de meest recente updates van de bronhandleiding weer. Help ons met het updaten van de vertaling of bekijk de bronhandleiding.
Wat je nodig hebt
Remove the two screws holding the battery in place.
Slip your finger into the finger hole provided at the top of the battery and lift to remove it.
Remove the five Phillips screws securing the bottom to the case.
Slide the cover up slightly to release the catches holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
Lift the bottom cover to remove it.
Remove the three Phillips screws securing the fan on the right.
Carefully unplug the fan's power connector.
Remove the first fan.
Remove the two Phillips screws securing the left hand fan.
Remove the six Phillips heatsink retaining screws .
Using the two black tabs as handles, lift and remove the heatsink.
To reassemble your device, follow the instructions in reverse order.
Met dank aan deze vertalers:
50%
Jerry Wheeler helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
