Inleiding
Use this guide to replace the steam nozzle on your Whirlpool Duet WED87HED.
The steam nozzle sprays a fine mist of water into the heated operating dryer to help prevent wrinkles.
If the steam nozzle malfunctions, you may notice decreased performance from your dryer.
This guide shows this repair performed with the drum removed for greater clarity. The procedures are the same.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:FixMat$36.95
Use a 5/16 inch nut driver to remove the two 15.7 mm-long screws securing the top panel to the rear panel bracket.
Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
Use a 5/16 inch nut driver to remove the 16.2 mm-long cover plate screw.
Use a Phillips driver or a 1/4 inch nut driver to remove the three 21.4 mm-long screws.
Use a 5/16 inch hex driver to remove the 16.5 mm-long green ground screw.
Use a Phillips driver to remove the two 15.3 mm‑long cord terminal block screws.
Use a 1/4 inch nut driver to remove the eleven rear panel screws.
Ten 20 mm-long screws
One 12.9 mm-long screw under the water inlet.
Lift the panel about 1/2 inch and tilt it to the rear to release it from the vent pipe.
Slide the panel off the vent pipe and remove it.
Make sure that the vent pipe is fitted into the collar on the panel.
Make sure the tabs at the bottom are aligned to the bottom rim of the chassis.
Position the panel so its screw holes match with the chassis.
Push the retaining clip out with a small screwdriver or spudger.
Grab the retaining clip with your fingertips and remove it.
Use a 1/4 inch nut driver to remove the 12.9 mm‑long sheet metal screw securing the steam nozzle cover.
Lift the lower edge of the cover and tilt it outward to clear the nozzle.
Slide the cover down to disengage the tab at the upper end of the cover.
Remove the cover.
Use a 1/4 inch nut driver to remove the 12.9 mm-long nozzle assembly screw.
Lift the nozzle assembly up to disengage the tab at the lower end.
Remove the nozzle assembly.
Repair didn’t go as planned? Ask our Answers community for help.
