Ga door naar hoofdinhoud
Whirlpool Duet Steam Washer Drain Pump Replacement
Wat je nodig hebt
  1. Whirlpool Duet Steam Washer Drain Pump Replacement, Drain Pump: stap 1, afbeelding 1 van 1
    • For your own safety, be sure to unplug the washer before proceeding.
  2. Whirlpool Duet Steam Washer Drain Pump Replacement: stap 2, afbeelding 1 van 1
    • To ensure that no more water passes through the washer, shut off the water by turning both handles all the way to the left.
  3. Whirlpool Duet Steam Washer Drain Pump Replacement: stap 3, afbeelding 1 van 3 Whirlpool Duet Steam Washer Drain Pump Replacement: stap 3, afbeelding 2 van 3 Whirlpool Duet Steam Washer Drain Pump Replacement: stap 3, afbeelding 3 van 3
    • Use a 1/4" socket or screwdriver to remove the sixteen 15 mm screws securing the rear access panel.
    • Remember: turn left to loosen and turn right to tighten!
    • Remove the rear access panel.
  4. Whirlpool Duet Steam Washer Drain Pump Replacement: stap 4, afbeelding 1 van 1
    • Pull the drain pump wire connector straight out of its port.
  5. Whirlpool Duet Steam Washer Drain Pump Replacement: stap 5, afbeelding 1 van 2 Whirlpool Duet Steam Washer Drain Pump Replacement: stap 5, afbeelding 2 van 2
    • Place your bowl or container under the drain hose before removal to catch any excess water that may be in the hose.
    • Use pliers to release the clamps securing the drain hose to the drain pump.
    • Pull the drain pump out.
  6. Whirlpool Duet Steam Washer Drain Pump Replacement: stap 6, afbeelding 1 van 2 Whirlpool Duet Steam Washer Drain Pump Replacement: stap 6, afbeelding 2 van 2
    • Use a 5/16" socket to remove the two 50 mm drain pump mounting screws.
    • There is one screw on each side of the pump.
    • Pull the drain pump down to remove it.
    • If it is difficult to remove, you can wiggle the pump in a side-to-side motion until it releases.
Conclusie
Edgar Ibarra
133 Reputatie
1 Handleiding geschreven
UM-KIM-S22SMG3 Lid van UM-KIM-S22SMG3
Meetup
4 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 53
Afgelopen 30 dagen: 303
Altijd: 2,187
