Inleiding
This guide demonstrates how to do a hand sewn whip stitch to close a fabric tear on a pair of Patagonia® Quandary pants. The whip stitch is a versatile technique that binds torn edges together with looping stitches, making it ideal for sealing small rips and preventing further fraying.
Hand sewn repairs are a fun and effective way to extend the life of gear at home. DIY repairs won't void the Patagonia warranty—they're actually encouraged!
Patagonia items can also be taken in to a local retail store for repair evaluation or sent in to Patagonia through their mail-in repair service.
Let's get fixing!
Related Tutorials
Related Articles
Wat je nodig hebt
When placed close together, whip stitches can also reinforce an opening to create a buttonhole or a decorative eyelet.
Locate the damaged area and trim away any loose or hanging threads.
In this tutorial, the whip stitch will be used to seal a short, straight tear with minimal fraying and fabric loss.
If the damage is more extensive, a variation of this technique can be used to attach a patch over the damaged area. See Whip Stitch on a Patch or Blanket Stitch on a Patch.
Cut a length of thread approximately 24 inches (~61 cm) long.
Thread the needle and adjust the thread so there are equal lengths of thread on each side of the needle.
Tie an overhand knot with both ends to create a doubled length of thread.
See Needles and Thread for more details.
Insert the needle up from the backside of the fabric, about 1/8 inch (~3 mm) diagonally away from the end of the tear. Pull tight so the knot is flush on the backside.
Pierce down into the fabric 1/4 inch (~6 mm) away from the first stitch, on the opposite side of the tear, then bring the needle back up right next to the first stitch, about 1/8 inch (~3 mm) away. Pull through.
Repeat the process from the previous step to continue stitching in a spiral pattern, passing the needle from one side of the tear to the other.
Maintain consistent tension and spacing for a neat appearance.
Continue whip stitching until you get to the opposite side of the tear.
Make a final stitch beyond the end of the tear to secure the stitching, just as it was anchored at the beginning of the tear.
Pass the needle through to the backside of the fabric.
Make a secure knot on the backside of the fabric using one of the techniques from Knot Thread to the Fabric (2 Ways) and trim the extra thread.
Check that the tear is effectively sealed and that the stitching has even spacing and appropriate tension.
Trim any loose threads.
4 andere personen hebben deze handleiding voltooid.
