Ga door naar hoofdinhoud
Wexford CT-166TF Plastic Casing Replacement
Wat je nodig hebt
  1. Wexford CT-166TF Plastic Casing  Replacement, Settings Knob: stap 1, afbeelding 1 van 1
    • Locate the knob at the top of the fan.
  2. Wexford CT-166TF Plastic Casing  Replacement: stap 2, afbeelding 1 van 1
    • Remove the knob by gripping it and pulling straight up. Use a spudger if it is difficult to grip.
    • When reassembling, be sure to align the bottom of the new knob and the turning mechanism in the fan before pushing down.
  3. Wexford CT-166TF Plastic Casing  Replacement, Plastic Casing: stap 3, afbeelding 1 van 1
    • Using the plastic opening tool, turn the device over and remove the black plastic covers over the four screw holes.
  4. Wexford CT-166TF Plastic Casing  Replacement: stap 4, afbeelding 1 van 2 Wexford CT-166TF Plastic Casing  Replacement: stap 4, afbeelding 2 van 2
    • Remove the four screws underneath the plastic covers.
  5. Wexford CT-166TF Plastic Casing  Replacement: stap 5, afbeelding 1 van 2 Wexford CT-166TF Plastic Casing  Replacement: stap 5, afbeelding 2 van 2
    • Remove 5 smaller screws visible through small holes between the base and the casing.
  6. Wexford CT-166TF Plastic Casing  Replacement: stap 6, afbeelding 1 van 2 Wexford CT-166TF Plastic Casing  Replacement: stap 6, afbeelding 2 van 2
    • Remove four screws on the back, two near the top and two near the bottom.
  7. Wexford CT-166TF Plastic Casing  Replacement: stap 7, afbeelding 1 van 1
    • Pull off the back casing.
  8. Wexford CT-166TF Plastic Casing  Replacement: stap 8, afbeelding 1 van 2 Wexford CT-166TF Plastic Casing  Replacement: stap 8, afbeelding 2 van 2
    • Remove the 2 screws that attach the front part of the casing to the motor.
  9. Wexford CT-166TF Plastic Casing  Replacement: stap 9, afbeelding 1 van 2 Wexford CT-166TF Plastic Casing  Replacement: stap 9, afbeelding 2 van 2
    • Remove the two middle screws attaching the black plastic cover to the front .
  10. Wexford CT-166TF Plastic Casing  Replacement: stap 10, afbeelding 1 van 1
    • Remove the two screws attached to the white bar near the red light on the top of the front casing.
  11. Wexford CT-166TF Plastic Casing  Replacement: stap 11, afbeelding 1 van 1
    • Remove the two screws keeping the button attached to the top of the casing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cameron Mattson
101 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S3-G4, Liner Spring 2017 Lid van UW Tacoma, Team S3-G4, Liner Spring 2017
UWT-LINER-S17S3G4
4 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 406
