Inleiding
The mini USB port is needed to access to the data or store new data on the hard drive. In order to attach the mini USB, you will need to know how to solder. When soldering, you run the risk of damaging the board (and yourself).
Wat je nodig hebt
Start by turning the device port side up.
With the plastic opening tool, pry along the edges of the case.
When you hear the case snap-out of its fitted grooves, slowly slide the board assembly out of the case.
To reassemble your device, follow these instructions in reverse order from step 8.
8 andere personen hebben deze handleiding voltooid.
