Ga door naar hoofdinhoud
Westcott iPoint Evolution Outer Casing Replacement
Wat je nodig hebt
  1. Westcott iPoint Evolution Outer Casing Replacement, Outer Casing: stap 1, afbeelding 1 van 1
    • Step 1: Start with the back of the pencil sharpener facing you.
    • This allows you to locate the power source.
  2. Westcott iPoint Evolution Outer Casing Replacement: stap 2, afbeelding 1 van 1
    • Step 2: Grab the end of the plug located at the bottom of the sharpener and pull it out gently.
  3. Westcott iPoint Evolution Outer Casing Replacement: stap 3, afbeelding 1 van 2 Westcott iPoint Evolution Outer Casing Replacement: stap 3, afbeelding 2 van 2
    • There are three parts of the sharpener.
    • Step 3: Grab the very top of the sharpener, twist it to the right and lift it up to remove it.
  4. Westcott iPoint Evolution Outer Casing Replacement: stap 4, afbeelding 1 van 3 Westcott iPoint Evolution Outer Casing Replacement: stap 4, afbeelding 2 van 3 Westcott iPoint Evolution Outer Casing Replacement: stap 4, afbeelding 3 van 3
    • Step 4: Grab the center of the sharpener and lift it up to remove the piece.
  5. Westcott iPoint Evolution Outer Casing Replacement: stap 5, afbeelding 1 van 3 Westcott iPoint Evolution Outer Casing Replacement: stap 5, afbeelding 2 van 3 Westcott iPoint Evolution Outer Casing Replacement: stap 5, afbeelding 3 van 3
    • Step 5: Remove the small ring that is around the sharpener.
    • This piece is below the center of the sharpener that you just removed.
  6. Westcott iPoint Evolution Outer Casing Replacement: stap 6, afbeelding 1 van 1
    • Step 6: Flip the pencil sharpener upside down.
    • Locate the four screws on the bottom of the sharpener.
  7. Westcott iPoint Evolution Outer Casing Replacement: stap 7, afbeelding 1 van 1
    • Step 7: Take a screwdriver and unscrew all of the screws on the bottom.
  8. Westcott iPoint Evolution Outer Casing Replacement: stap 8, afbeelding 1 van 1
    • Step 8: After all the screws are removed gently take off the bottom of the sharpener.
  9. Westcott iPoint Evolution Outer Casing Replacement: stap 9, afbeelding 1 van 1
    • Step 9: Carefully lift the lid off of the sharpener.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Lilly
167 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 97
Altijd: 10,701
