Ga door naar hoofdinhoud
Wen 2307 Speed Adjustment Assembly Replacement
Wat je nodig hebt
  1. Wen 2307 Speed Adjustment Assembly Replacement, Front Panel: stap 1, afbeelding 1 van 1
    • Unscrew the locking sleeve.
  2. Wen 2307 Speed Adjustment Assembly Replacement: stap 2, afbeelding 1 van 1
    • Remove the hanging clip.
  3. Wen 2307 Speed Adjustment Assembly Replacement: stap 3, afbeelding 1 van 2 Wen 2307 Speed Adjustment Assembly Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the six 8mm PH2 screws.
  4. Wen 2307 Speed Adjustment Assembly Replacement: stap 4, afbeelding 1 van 1
    • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
  5. Wen 2307 Speed Adjustment Assembly Replacement: stap 5, afbeelding 1 van 1
    • To remove the front panel, pry the device apart while holding the device with the other hand.
    • The front panel should come out easily.
  6. Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: stap 6, afbeelding 1 van 2 Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: stap 6, afbeelding 2 van 2
    • Identify the screws.
    • Unscrew the two 3mm phillips PH2.
    • Don't forget to put them appart from the ones unscrewed before.
    • Phillips PH2
    • Flathead 2.5mm
  7. Wen 2307 Speed Adjustment Assembly Replacement: stap 7, afbeelding 1 van 1
    • Remove the place boar carefully.
  8. Wen 2307 Speed Adjustment Assembly Replacement: stap 8, afbeelding 1 van 1
    • Pull out the power cable connectors.
  9. Wen 2307 Speed Adjustment Assembly Replacement: stap 9, afbeelding 1 van 1
    • Pull out the cord sleve for the new cable replacement.
  10. Wen 2307 Speed Adjustment Assembly Replacement, Speed Adjustment Assembly: stap 10, afbeelding 1 van 1
    • Remove the connected wiring from the circuit board.
  11. Wen 2307 Speed Adjustment Assembly Replacement: stap 11, afbeelding 1 van 1
    • Remove the single 4mm screw retaining the circuit board.
  12. Wen 2307 Speed Adjustment Assembly Replacement: stap 12, afbeelding 1 van 1
    • Gently pry the circuit board from the back piece.
Conclusie
Dominick Chavez
137 Reputatie
1 Handleiding geschreven
USF Tampa, Team 12-1, Eyestone Spring 2016 Lid van USF Tampa, Team 12-1, Eyestone Spring 2016
USFT-EYESTONE-S16S12G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 730
