Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases.
Pull the connector away from the connector port.
Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases.
Grasp the temperature probe and pull it up to remove it from the monitor.
Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
Remove the flathead screw on the USB networking door.
Loosen the captive Phillips #2 screw securing the monitor to the stand.
Holding the monitor securely, open the USB networking door.
Detach any accessory USB cables from USB ports on the monitor.
Insert a coin into the slot and push to open.
Remove the battery cover.
Use the plastic label to remove the battery from its recess.
Remove the four Phillips #2 screws (labeled 14 in the service manual) from the rear housing.
With the handle/alert bar facing you, begin to lift the rear housing from the left side, holding the right side securely.
Disconnect the fan cable (labeled connector A in the service manual) from its socket in the power supply.
Unplug the small USB connector from its socket (labeled J4 in the service manual).
Disconnect the communications power cable from its socket (labeled J50 in the service manual).
Unplug the large USB connector from its socket (labeled J8 in the service manual).
Press the tab on the ethernet cable and unplug it from its socket (labeled J9 in the service manual).
The power supply cable is secured by an interlocking connector that must be held open to unplug the connector.
Grasp the power supply cable firmly and lift both it and the spudger from the channel in the power supply housing to unplug the connector.
Één andere persoon heeft deze handleiding voltooid.
