Inleiding
Use this guide to remove or replace a vital signs module from a Connex monitor.
This guide shows to procedure to remove a module from a standard chassis. The procedure can be repeated to remove the second module from the standard chassis, and the third module from an extended chassis.
PLEASE NOTE: This repair guide was developed by the iFixit team based on Welch Allyn's own service manual. Neither iFixit nor this repair guide is endorsed by or affiliated with Welch Allyn.
Wat je nodig hebt
Remove the four Phillips #2 screws (labeled 14 in the service manual) from the rear housing.
Disconnect the USB cable from the module.
For the extended chassis: Disconnect the two USB cables from the module.
3 andere personen hebben deze handleiding voltooid.
