Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases.
Pull the connector away from the connector port.
Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases.
Grasp the temperature probe and pull it up to remove it from the monitor.
Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
Remove the flathead screw on the USB networking door.
Loosen the captive Phillips #2 screw securing the monitor to the stand.
Holding the monitor securely, open the USB networking door.
Detach any accessory USB cables from USB ports on the monitor.
Insert a coin into the slot and push to open.
Remove the battery cover.
Use the plastic label to remove the battery from its recess.
4 andere personen hebben deze handleiding voltooid.
